Reading HDF5 files
I am trying to read the HDF5 file attached to this post using the LabVIEW blocks written by Jason S.
I can manage to read the 'Simulation time' section of the data set but not the 'Signal' it keeps giving a conversion error from source to destination.
I have attached the VI called main which is the closest to reading anything from the HDF5 file if the 'Signal' element is removed out of the cluster.
I can read the file fine using HDFView program and using code within Matlab, however I need to use LabVIEW as a license for Matlab is much more expensive.
Can anyone advise what I am doing wrong?
Tom Horsfall
(4,373 Views)
I don't have Jason's code installed, but looking at your code, and given your error, it appears you are setting up your datatype incorrectly.  The dataspace is a simple unlimited 1D array.  The datatype is a compound datatype composed of a 64-bit float and a 32-bit float.  However, it appears from HDFView that the first element is a 1D array with one element and the second is a 2D array with one element (second signal set is different).  It does not appear you are creating this datatype and properly using it to fetch your data.  This would cause your conversion problem.
Hopefully this helps.  I have not really used HDF5 in several years, so take my advice with a grain of salt.
(4,369 Views)
Hi DFGray,
I will try using a 2D array compound today and see if that fixes the problem.
I have been through different types for this variable before and have struggled to read it.
Will keep you posted
Tom
(4,342 Views)
I have tried many different combinations of data type into the block and am having no success with reading the file.
I have even tried mimicing the process that works in matlab within LabVIEW with no success.
Any other thoughts?
Tom
(4,322 Views)
Hello Tom,
s. the attached vi.
Best Regards.
(4,018 Views)
This is better.
(3,995 Views)
