Reading FIFO's in SCTL does not work as a FIFO
I hope this is enough, if not can i post some simple VI's tomorrow.
I have a weird behaviour in my SCTL when reading two instances of the same FIFO, which is set to "never arbitrate".
Below
Im sending an array into the FIFO, for example
fifo_array = [0, 0, 0, 0, 0, 0, 1]
Below i have posted two ways of extracting the array, where i am gathering the data in some fixed arrays of size 4.
Optimal readout which should work, but doesn't:
Return value of analog value = [1,1,1,1]:
Does work:
return value of analog values = [0,0,0,1]
Is there any obvious reason for why this should not work ?
Message 1 of 9
(3,858 Views)
I don't think you could do two FIFO reads in a single cycle, can you?
(I don't do much FPGA.)
Try reading two elements at once instead of reading one element twice.
Message 2 of 9
(3,836 Views)
That would explain it, i just thought that LabVIEW would complain when i try to compile it.
When you say "Try reading two elements at once instead of reading one element twice.", do you mean pipelining or is there some way that i can read two elements at once ?
Message 3 of 9
(3,829 Views)
Accepted by topic author Zulsig
You need to check the "Timeout" flag.  The FIFO simply returns the last value on a Timeout. If you want to avoid this, then you need to make sure you parse the "Timeout" output of the FIFO accordingly. That could be one problem.
Any reason  why you're sending 7 elements per FIFO and reading 8?
The second is that we have no idea how you're filling the FIFO...... So your statement "This should work" cannot be verified. It also seems like a really weird way of parsing data from a FIFO. Can't you just use a single "Read" primitive and wire the output to a case structure which alternates between the two arrays?
Message 4 of 9
(3,816 Views)
That a mistake, i am sending 8 elements per FIFO
 Fifo_write = [0, 1, 2, 3, 4, 5, 6, 7]
Im filling the FIFO with the help of NiFPGA in python:
https://github.com/ni/nifpga-python
After the FIFO's is loaded the FPGA-target-VI runs.
Yes, i don't know why i did it like this, thank you!
This clearly improves it, but just to be sure, is it theoretically possible to read two instances of the same FIFO in a SCTL ?
Message 5 of 9
(3,805 Views)
This is not an answer to your question, but in your second screenshot you are missing a data flow dependency between your two SCTLs, so there is no way to predict which loop will execute first. Since this code runs on a FPGA it will probably run in parallel.
Regards, Jens
Kudos are welcome...
Message 6 of 9
(3,801 Views)
Thankyou, that was the problem i was having at the moment!
When i rearranged i forgot to put a wire between the FIFO's to force dataflow.
Message 7 of 9
(3,799 Views)
So are you saying you have your screenshots reversed? Did the one with the sequence structure work but the one with embedded SCTLs work? I ask because I understood the opposite from your post.
Message 8 of 9
(3,790 Views)
Sorry, i was a bit to fast in posting my question.
1. The screenshot without the sequence structure, so the one with two SCTL is the one that works.
2. There is a fault in the screenshot, there is supposed to be a wire connected from the first FIFO's reference out to the second FIFO's reference in. that is to ensure dataflow.
I have restructured my loop like this for now (Which works).
Message 9 of 9
(3,783 Views)
