Reading Excel File Properties in LabVIEW
I have a large amount of excel data files I am reading into a labview program.  I want to use the date created property of the files to select only files in a date range.  How do I read this file property?
(3,590 Views)
Accepted by spiff40k
It's dangerous to go alone! Take this.
Cheers
(3,584 Views)
Thank You! That helped.
(3,578 Views)
No problem! In general, you can get all of the information you need that you could normally get using Windows, you just have to use the Windows API.
Cheers
(3,572 Views)
