Reading Binary Data using TCP/IP
Now that you mention it, we have Balances with TCP/IP ports (as well as USB) and we definitely use VISA to "talk" to them.  We give it a command (a few letters, I forget the syntax) and the Balance gives us a multi-byte Response (which we parse).  We definitely code this in LabVIEW using standard VISA functions -- the TCP/IP-ness of it is buried in MAX, we just treat it as a VISA peripheral that reads and writes bytes.  Pretty simple ...
Message 21 of 24
(1,441 Views)
Just wondering how do I break out the string function to read out 3 outputs separately
Message 22 of 24
(1,406 Views)
Look at the functions in the string palette.
Message 23 of 24
(1,391 Views)
You could use String Subset, Scan From String, or Search/Split String
Message 24 of 24
(1,385 Views)
