12-10-2007 05:37 PM
12-11-2007 08:48 AM
I should probably clarify, I need to read 1 frame at a time. If I read all the frames at once then I run out of memory.
Gary
12-11-2007 09:54 AM
12-11-2007 10:04 AM
Thanks for Responding, Here is my code so far. I think everything works up to the read Dataset.
12-11-2007 10:45 AM
12-11-2007 11:05 AM
I tried that at first but I get the following error. HDF Error in call to HSDread. Dataspace interface Out of range: selection+offset not within extent. (Error 14,4)
12-11-2007 11:19 AM
12-11-2007 11:55 AM
OK tried that and got the same result. Here is my code now. Thanks for looking.
gary
12-11-2007 12:29 PM
12-11-2007 02:30 PM
You Da Man!!!!!!!!!!!!!!!! That did it. Nothing can stop me now. Thanks, MUCH.
gary![]()
