Read the LabVIEW help file
Forgive me if this is remarkably simple answer.
Id like to be able to read LabVIEW help file on my LapTOP which has no LV installed.
If I can do this from, here as in this forum can it be done?
(3,847 Views)
Available to download here
(I like the simple questions,  and other's may want the same info)
"Should be" isn't "Is" -Jay
(3,845 Views)
Too bad the download is in .chm format!  Something cross-platform would be nice!
Lynn
(3,820 Views)
Lynn
Lynn,
Zip a MAC version attach it here and tag the darn thing please.  You are correct a cross-platform help download would be nice
(3,813 Views)
The LabVIEW help is also online with the HTLM view.
LabVIEW 2013 Help [2013 version of the LabVIEW Help is no longer available online]
(3,801 Views)
Jeff,
I will work on that.
What I really was after was the DAQmx VI help.  That gets installed when DAQmx is installed.  I have the VIs (copied from a Windows instrallation). They do not work of course because the core .dll is missing. But that process does not get the help files.
I did search and found that there are programs available on the Mac which can process .chm files.  I installed two and then downloaded the file you linked. That has the LV help. After some searching in the NI documents pages I found the DAQmx help and the DAQmx VIs help .chm files. Some links tend not to work, but this has given me access to the stuff I wanted.
For any other crazy Mac users who want to read help files on VIs you cannot run, I have tried CHM Reader, available through the Apple App Store, and iChm, which I found at https://www.macupdate.com/app/mac/28171/ichm . CHM Reader seems to be a bit more robust with the NI files.
Thanks.
Lynn
(3,789 Views)
LabVIEW 2013 Help
Thanks crossrulz!
Thats the one I thought was available.
Yeah the chm thing is a reap PITA when using win7 work PC with high security settings.
(3,759 Views)
