Read multiple files in folder and append data to one file
Sir I programmed to append a couple of files in a single text file.
But I want to append a certain range of text files with string names for example ABC040 to ABC110 from 1000 files naming from ABC000 to ABC999, what will the tool for selecting this range according to their file name??
Message 21 of 22
(1,009 Views)
Hey rchkrishna,
You've replied to a thread that's extremely old. If you're having an issue or need some help, it would be best if you create a new thread with your issue. Try and give some more background (software version, attempted solutions, any code you're using) to help people help you.
Cason
Cassandra Longley
Senior Technical Support Engineer - FlexRIO, High Speed Serial and VRTS
Message 22 of 22
(983 Views)
