Read from a created text file
I have hopefully a quick question.
Why doesn't the read from text file work in this example?
Dan Shangraw, P.E.
(3,538 Views)
Accepted by ASTDan
When you write to a text file, LabVIEW keeps a pointer along with the reference while you have the file open. So after you write "test" to the file, your new pointer is now at location 4. When you Read after that, it reads from pointer 4 and on.
Use the Set File Position function in the advanced palette to read from position 0.
Cheers
(3,531 Views)
I think you need to set your file position back to zero after the write. You're reading back from the position after your write which is probably empty.
EDIT: James is too fast for me 🙂
(3,529 Views)
Sorry, Taki!
ASTDan, this altered version of your code will just result in a file getting larger and larger with each run with "testtesttesttest" and so on.
Cheers
(3,521 Views)
Thank you!
Was really scratching my head on that one.
Dan Shangraw, P.E.
(3,506 Views)
