Read from a XY graph
I made a XY graph from an array. I want to read the corresponding value of X from a graph. Is it possible to do this ?
(3,562 Views)
You know the data going in.  So you can use Threshold 1D Array and Interpolate 1-D array to get the corresponding X value for any given Y value.
(3,537 Views)
Can you tell me how to do that ?
(3,532 Views)
See this older thread.
http://forums.ni.com/t5/LabVIEW/Finding-a-Y-value-for-a-given-X-value/m-p/2490730
Altenbach's message in that thread http://forums.ni.com/t5/LabVIEW/Finding-a-Y-value-for-a-given-X-value/m-p/2490820#M760269 was the best implementation and only required a cluster and an interpolate 1-D array.
(3,526 Views)
I tried to do that but I m not getting any ans.
I want the left one to be my Y and the right to be my X.
Please check this
(3,486 Views)
I don't know what you are referring to when you talk about the left one vs. the right one.
There is something I had forgotten about with Interpolate 1-D array.  And I'm not finding it clearly documented in the help for that function right now.  But I believe it requires the numbers for Y to be in an increasing order.
So try putting in a Reverse 1-D array for both the X and Y inputs before bundling them in the cluster.
(3,478 Views)
