Read datas from table
Hi danil,
right now you send 55 strings, but you only read 10 of them...
Thinks first, then program!
Message 151 of 189
(887 Views)
55 strings?But when I placed an array here:It is showing exact values.Please tell me how to correct it.
Thanks as kudos only:)
Message 152 of 189
(885 Views)
Hi danil,
count the number of strings you're sending and you will see it's 55. Hint: 1+2+3+...+9+10=55...
Message 153 of 189
(882 Views)
YES,then what to do with the auti-indexed loop.please give some hints.Is the read VI ok?
Message 154 of 189
(878 Views)
Hi danil,
it's ok - besides it reads less strings than are sent due to fixed loop count...
Message 155 of 189
(873 Views)
I can't get it properly.You mean I have to replace it with continuous loop?
I replaced it with while loop,It is displaying array in down to top order.
Is there any changes have to be made in write VI??
Message 156 of 189
(871 Views)
Hi Danil,
"I replaced it with while loop,It is displaying array in down to top order."
Then I would change the order of collecting the strings...
Message 157 of 189
(868 Views)
Replacing the for loop with while loop in the read side,Is that the correct method??
Why it is reading in the reverse order?
Message 158 of 189
(864 Views)
Hi danil,
"Replacing the for loop with while loop in the read side,Is that the correct method??"
You don't need to replace the FOR loop, but you can. The point is: you have to read as many strings as you send...
"Why it is reading in the reverse order?"
I doubt it is reading in reverse order. Probably it is only displaying in reversed order. Quite a difference...
Think first, then program!
Message 159 of 189
(861 Views)
1.By viewing the attached code,can you tell me it is reading in reverse order due to any problem in the code?
Message 160 of 189
(858 Views)
