Read datas from table
Hi Danil,
what's the meaning of "\\"? What does the context help say about that? Where does it come from? Search for yourself!
Message 171 of 189
(1,068 Views)
Iam getting \\n only when Iam attaching \n with constant(FF)
Everything else is working as expected: the strings sent by your WriterVI are received by the ReaderVI and displayed in receiving order..
But how it is??It is not working as expected.Still displaying in reverse order.
Thanks as kudos only:)
Message 172 of 189
(1,064 Views)
Can't able to find why "\\" is coming.Is it due to this problem Iam getting unexpected results??
Message 173 of 189
(1,041 Views)
First, I'm impressed by GerdW still helping you. You where told to go through the tutorials, and you agreed on doing so. But still you are asking question about a very simple program. And you are asking basic questions that has already been answered in this tread.
Go through this tread and if you can find the answer to you own question, it is there.
Spoiler
How are the constant been viewed ? \-code or normal ?
Message 174 of 189
(1,031 Views)
Hi dk,
shhh - I hoped to play that game another 20 messages 🙂
Message 175 of 189
(1,027 Views)
      How are the constant been viewed ? \-code or normal ?I can't found out this thread
      The difference between LF characters and normal characters I understand.Will you please run this attachment.Please point out the exact problem area.I will do it myself
Message 176 of 189
(1,023 Views)
Hi Danil,
why do you close the COM port two times? To be sure it's getting closed???
You have been told a lot of times about the importance of the correct display mode for strings. Still you fail in setting your strings to the correct display format. You already spotted the critical point in one of your last messages. Why don't you check this again?
DKFire told you what to check, you already know where to check - so what's your problem now?
"Will you please run this attachment."
As I told you before I don't have two COM ports available, so cannot run your VIs.
Do you ever read any messages here?
Message 177 of 189
(1,017 Views)
Yes I really did.
Actually I asked you many times that I failed to find out why \\n is coming?And the array2 is not showing that.Iam asking 'one' and you are asking another one.
Message 178 of 189
(1,014 Views)
Hi Danil,
take your VI from message#176, read what DKfire wrote in message#174 and look at the spot you already found in message#170.
What is your problem - apart from not being able to combine facts you already have been told?
Message 179 of 189
(1,009 Views)
Yes,I removed that one.I have given that one according to your instruction in #146.Smiley Surprised
Message 180 of 189
(1,004 Views)
