Showing results forĀ
Search instead forĀ
Did you mean:Ā
Read data of embedded web page
Hi Wilmer,
attached you will find an example. Maybe it possible to use the embedded webbrowser if the connection is established and the authentication is done. You have to insert a vi which calculate the BASE64 code from the user:password, for the moment i don't have it for LV7.1.
Is it a solution for you to work without the embedded webbrowser (do you mean the ActiveX WebBrowser?)?
Hope it helps.
Mike
Message 21 of 37
(2,102 Views)
SSK, I have tried with  but not working.
MikeS81, can you give a sample?
Message 22 of 37
(2,097 Views)
Hi Wilmer,
what for do you mean?
Mike
Message 23 of 37
(2,091 Views)
Hi MikeS81, I tried to do a test with the VI that you posted, also I encoded the user and pasword en code64, but neither works, the labview preset  code56 Error.
Message 24 of 37
(2,070 Views)
Hi Wilmer,
where do you get error 56? Did you debug it?
If i run the posted vi, then i can get the first page, which states that i am unauthorized. So i think with the correct user and password i would also get the final page.
Mike
Message 25 of 37
(2,058 Views)
Hi MikeS81, the error is on the  401 case, see the attach
Message 26 of 37
(2,044 Views)
Hi Wilmer,
try to increase the timeout of the read function.
Mike
Message 27 of 37
(2,036 Views)
Hi MikeS81, I did that, to increase the timeout a 25000 but the problem is the same Smiley Mad
Message 28 of 37
(2,030 Views)
I don't think IE supports usernames and passwords in the URL at this point in time as the default behavior.  The following support document speaks to this and some possible workarounds.  It may be possible to revert to the old behavior if you have access to the machine that is performing the authentication.
http://support.microsoft.com/default.aspx?scid=kb;[LN];834489
Message 29 of 37
(2,023 Views)
Hi Boltzmann, You're right, Windows versions of Internet Explorer from version 6 can not treat user usernames and passwords in HTTP URLs Smiley Sad My IE is version7 !!!
But there will ho another method using Labview so you can access a website by entering the username and passwords?
Message 30 of 37
(2,010 Views)
