Read data from instrument through Visa Write
Hi Friendly Smart Labview Community!!
I try to read data from instrument but it can not control my led.
Depend on the interface in Labview, I see I already read data but the led didnt light.
I hope the community can give me some solutions or advices. Thank you so much, you guys!!!
int ledPin = 8; // Chân nối LED
void setup() {
  Serial.begin(9600); // Khởi động cổng Serial ở baud rate 9600
  pinMode(ledPin, OUTPUT); // Đặt chân LED làm đầu ra
void loop() {
  if (Serial.available() > 0) { // Kiểm tra xem có dữ liệu nào đang chờ để đọc không
    String receivedString = Serial.readStringUntil('\n'); // Đọc một chuỗi từ cổng Serial đến khi gặp ký tự xuống dòng
    // Chuyển đổi chuỗi thành số thực
    float receivedFloat = receivedString.toFloat();
    // Kiểm tra giá trị nhận được
    if (receivedFloat >= 0.55) {
      digitalWrite(ledPin, HIGH); // Bật đèn LED nếu giá trị nhận được lớn hơn hoặc bằng 0.65
      Serial.println("1A");
    } else {
      digitalWrite(ledPin, LOW); // Tắt đèn LED nếu giá trị nhận được nhỏ hơn 0.65
      Serial.println("0A");
(1,355 Views)
Due to data flow and the flat sequence structure, you are never getting to the loop for writing to the Arduino.  I would try to put everything in a single loop.  It will make your life a lot easier.
GCentral
(1,294 Views)
Good evening sir!!
This block is drive from the E-load (I use USB interface to read data), we need it to collect data.
I want labview can read data from E-load and transfer this data to arduino to control the led. Can you advise again the flow code in order to I can get data.
And can i ask sir a favor, Could you reference me the link to study more about collect serial string data form labview to arduino and split it in arduino. Thank you so much, sir
(1,286 Views)
Good morning sir
I'm so sorry, I forgot to send the drive of E-load, so sir cant open the file
I tried to get data during 2 weeks but I didn't know what happen with my code. I hope sir can give me some advices or solutions. Thank you so much, sir!!
void setup() {
void loop() {
    } else {
(1,259 Views)
