Read current plot range
It's easy enough to read the default Y Scale plot range for any plot of a stacked chart, but this property doesn't appear to follow the currently applied range (EX: Manually zoomed or manually entered in an axis during execution).  What property stores the current Y scale settings then (Autoscale, min, max, etc)?
XL600
(5,284 Views)
There is a YScale sub-menu when browsing for properties. This includes the Range maximum, minimum, etc.The auto-scale property is in the form of "YScale.ScaleFit".
These properties do change when the user zooms, or manually types in to the ranges.
Try this out:
Cheers
(5,280 Views)
check this vi it will help you friend
(5,264 Views)
Accepted by xl600
If you have stacked plots, you need to write to the Active Y Scale property to read the scale information for that specific plot.
Cheers
(5,252 Views)
Thanks, that was the thing I was missing.  I have another VI which was changing the active Y axis in an event that I didn't spot.  It was changing it back to defaults for that axis (Based on a global set of axis settings).
XL600
(5,243 Views)
No problem. The whole Active Plot thing always seemed to bite me in the butt for a while until I got in the habit of checking for it. Sometimes I wish that the properties would have an array input/output option as well.
Cheers
(5,234 Views)
