Read csv into individual arrays
I'm trying to read a csv file with 2 columns into 2 separate arrays for interpolation. But I am unable to convert the read data into arrays.
Attached is the VI for reading and displaying data.
(11,685 Views)
Accepted by topic author utkarsh.17
You probably should also attach one of your csv files.
(In general, to get a row or column, "index array" is the right function, just keep one index dimension disconnected.)
(11,676 Views)
Here is an example csv
(11,663 Views)
Thanks. I first used transpose and then index to get x and y.
(11,659 Views)
As altenbach said, you're looking for the Index Array function.
You can drag the bottom edge downwards to get two indexing operations in one node. Just wire the 'Column' index and leave the row index blank.
GCentral
(11,645 Views)
If you wire to the lower dimension, you don't need to transpose.
(You can also select "transpose" when you read the file (boolean input). Then simply omit wiring any indices to get the first two columns.)
(11,642 Views)
Worked perfectly. Thanks for the help 😄
(11,633 Views)
