Read attributes from XML
Hi Anil,
Using //*@  gave me all the nodes/attributes from the XML.
So I wasn't looking for matching.
I then parsed out the text to get my data.
Akbar
Message 11 of 18
(3,050 Views)
@anilkumarmuppirala18 wrote:
Could you please explain why you gave //*@ as the string constant to get all matched nodes
thanks in advance
Anil
I'm no expert, but I think that's just standard XPATH stuff.  https://www.w3schools.com/xml/xpath_intro.asp.
Bill
CLD
(Mid-Level minion.)
Message 12 of 18
(3,040 Views)
Thanks akbar ,
but is there a way to get specific attributes because i tried using element name and its not working its not even giving me error
Message 13 of 18
(3,034 Views)
Hi Anil,
I understand your frustration with XML. I feel this is very peculiar with LabVIEW. If you have a XML file  (not created by LabVIEW) then you always have issues getting a particular attribute. It works sometime seamlessly and sometimes it doesn't. As you mentioned it won't give you any errors as well.
So the best way to do this, is to read the entire XML file as a string and parse it using string functions to get the attribute value you want.
Hope this helps.
thanks,
Akbar
Message 14 of 18
(3,019 Views)
Thanks akbar ,
Yesterday i struggled for 3 hours before finnaly finding a solution i was not using the right syntax . i looked up how xpath works and found this syntax its working for me now.syntax :- location to node containing attribute followed by @* Eg:-/rapishape/packagetypes/package/@*
hope this helps who ever is looking for this in future
 https://www.w3.org/TR/1999/REC-xpath-19991116/
Message 15 of 18
(3,008 Views)
may i know what is the name of the last block used out of 3 blocks used
Message 16 of 18
(2,968 Views)
If you refer to my post using JKI Easy XML the name of the function is Variant To Data from Cluster, Class & Variant -> Variant palette.
Ben64
Message 17 of 18
(2,963 Views)
Which message are you replying to?  (It helps to use the "Quote" button when your message could be ambiguous.)
I'm going to guess Ben64's message #5 since it has 3 functions in it.  That is a Variant to Data function.
Message 18 of 18
(2,960 Views)
