Read attributes from XML
Hi, I need to read data from an XML file, but since I'm fairly new to Labview and XML, I could really use some help.
Below is the content of the XML (part of it)
I need to read the serial number and weight from resource "ID1" and "ID8".
<resource name="printer">
<resource name="ID1">
- <counters>
  <counter description="product number" name="48030" type="lifetime" value="11081034" />
  <counter description="Weight [g]" name="48031" type="lifetime" value="692" />
  <counter description="Warm hours [h]" name="48032" type="lifetime" value="1454" />
  </counters>
<resource name="ID8">
- <counters>
  <counter description="product number" name="48030" type="lifetime" value="11081042" />
  </counters>
</resource>
Message 1 of 18
(11,960 Views)
Why don't you try using Easy XML toolkit.
Its Demo version is free. 🙂
Message 2 of 18
(11,944 Views)
Here's a way to do it using the LabVIEW XML Parser functions.
Ben64
Message 3 of 18
(11,932 Views)
Hi, thanks for the replies.
I started out with putting all data in an array, but it is simply to complex.
I had a look at EasyXML and it looks very promessing, but I can someone please help me with creating a cluster for the above mentioned XML?
Message 4 of 18
(11,907 Views)
Here is how to use the JKI Easy XML functions to convert between clusters and XML strings.
Ben64
Message 5 of 18
(11,892 Views)
Thank you Ben, it was very helpful.
How'd you use the Easy XML to convert from XML to cluster or array of clusters for the same example?
Message 6 of 18
(11,832 Views)
 Refer to example:
"<LabVIEW>\examples\JKI\EasyXML" .
Also you can get complete documetation for the same here
if you need to create parse data from XML you'll need to create the custer control (or constant as i do in the example in link given below) then parse the data from the XML to the output cluster.
I have created the code for your XML data here in dropbox (unable to attach VI on this forum due to error)
Message 7 of 18
(11,816 Views)
When you paste the XML code it into the string control, the resulting cluster is not populated correctly.
Also, would the behavior be the same if I create an array of clusters for counter?
Message 8 of 18
(11,803 Views)
It helped a lot, getting all the attributes from a file
Message 9 of 18
(10,602 Views)
Could you please explain why you gave //*@ as the string constant to get all matched nodes
thanks in advance
Anil
Message 10 of 18
(9,903 Views)
