Read and copy data of the cluster
I want to drag and drop an object by using mouse. Coordinates of the object are recorded in the cluster. How can i read and copy data of the cluster?
Thanks!
~drycsr~
(2,738 Views)
Hi drycsr,
you can use unbundle by name to read data from your cluster. Is this what you need? The coordinates of which object are recorded in the cluster?
Mike
(2,734 Views)
Hi Mike,
Actually it is not what i need.. Dragged object data is recorded.
In summary there are two objects. When i drag second object to same coordinates of the first object, it places on top of the first one. i dont want to stow objects. i want to put them side by side. And i record the dragged object coordinates.
Thanks!
~drycsr~
(2,727 Views)
Hi drycsr,
i'm not sure what you are doing. Can you show your vi?
Mike
(2,719 Views)
Thanks for your help Mike.
I finally figured out what was wrong.
Thanks!
~drycsr~
(2,673 Views)
