Read Waveform Data in C
Dear community,
I am looking for a way to read waveform data file with external software like C or Java.
The Data Acquisition, very simple code, is written and run in LabVIEW 2009SP1.
(see attachment)
Is an prepared header for data struct, open(), read(), close() this file format?
Anybody an idea? I didnt find anything here.
esod
(3,276 Views)
Hi esod,
see this:
I'm saving an array with just one waveform in it. The resulting file contains:
0000 0001 - array size (one waveform in the array)
0000 0000 D156 9847 5451 8000 0000 0000 - timestamp of first waveform
3FF0 0000 0000 0000 - dt value (1)
0000 0003 - array size of Y component
0000 0000 0000 0000  - first sample (0)
3FF0 0000 0000 0000 - 2nd sample (1)
4000 0000 0000 0000 - 3rd sample (2)
remaining stuff: the variant containing no attributes (?) in this example.
Timestamps use 128 bits in LabVIEW. Samples and dt use DBL datatype. Arrays have their size prepended as I32. Variant is a monster of it's own…
Forgot to mention in the first place: Those are internal representations of LabVIEW datatypes. They might change with each LabVIEW version (as happened to the timestamp long time ago), but I guess it is unlikely for the current waveform datatype…
(3,244 Views)
And an extra tidbit: the data is default saved in network byte order (big endian). Your C code will normally use the CPU default byte order which is little endian on x86/x64 platforms. So don't forget to swap the bytes and words when reading LabVIEW data into C.
Rolf Kalbermatter  My Blog
(3,224 Views)
