Read MODBUS Registers
It's a USB/Serial converter.
Message 11 of 32
(3,318 Views)
Accepted by topic author buickgn
buickgn,
This may be a problem with the USB converter/driver.  Suggest you modify your vi to use a VISA Write to write out your known good query string, wait and then read the expected number of bytes and see what happens.
Message 12 of 32
(3,311 Views)
Wayne,
It works fine with the Modbus Poll program which leads me to believe it's not a driver issue. I tried your suggestion here:
It sends the right command, however, in the "Read Buffer" it just repeats the command I sent.
Message 13 of 32
(3,303 Views)
buickgn,
I don't think you need the carrige return on the end of the write string.
Message 14 of 32
(3,296 Views)
You're right, I got rid of that. Still repeating the request. Here's a screenshot of the trace:
Message 15 of 32
(3,293 Views)
Is the written command being echo'd by the serial adapter?  What happens if you try to read more characters with the simple read/write string vi?
Message 16 of 32
(3,283 Views)
If I set it to 17, I get: 0203 0002 0002 65F8 0203 0439 0F7F 7394 79. Anything larger than 17 and it throws a timeout.
Message 17 of 32
(3,279 Views)
Wayne,
That was the issue, it's sending back the correct response after it echos the request. I guess the Modbus library doesn't play nice with this particular usb/serial converter!
Message 18 of 32
(3,276 Views)
Can you disable the echo?  Any driver settings?
Message 19 of 32
(3,272 Views)
It doesn't look like it. I'm in device manager looking at all the settings and don't see anything to enable/disable the echo.
Message 20 of 32
(3,270 Views)
