Read Delimited Spreadsheet VI not populating array with spreadsheet data
I am trying to import excel data into a LabView VI and from some reading that I did online, I figured the best way to do that would be to use the Read Delimited Spreadsheet VI. I am using LabView version 2020.
This VI is extremely simple at the moment. All I am doing is inputting the excel spreadsheet into the VI's file path node and then displaying all its rows on the front panel. I read that the VI cannot interpret a .xlsx file and requires a .txt file in stead so that is what I am inputting. There is very little room for error here, but I cannot get to read the data.
I am attaching pictures of the block diagram and the output on the front panel (it shows all zero values) below. If anybody could please take a look at them and help me figure out what I am doing wrong, that would be really great!
Thank you!
Message 1 of 11
(2,736 Views)
Your text file... is it tab delimited?
Bill
CLD
(Mid-Level minion.)
Message 2 of 11
(2,732 Views)
Yes, it is tab delimited.
I am still extremely new at LabVIEW as you might be able to tell.
Do you have any idea what the problem here could be?
Message 3 of 11
(2,714 Views)
Yes, we could solve the problem in a millisecond if you would attach a zip file containing your text file and VI.
(Is it really a simple text file or did you just change the extension of the excel file to *.txt? How does it look like in notepad?)
(Alternatively, we can stare for weeks at your picture and guess a million possible reasons. Not worth it!)
And no, it does not show "zero values". It shows an empty 2D array! Do you know the difference between orange and blue? Did you actually press the run button?
Message 4 of 11
(2,686 Views)
Thank you so much!
I am attaching the .vi and the .txt file.
The text file is a very basic 2 column, 10 row spreadsheet that I made just to test the read function was doing what I wanted it to do. I made it originally on excel and then saved it as a  tab delimited text file.
Message 5 of 11
(2,670 Views)
Works just fine here.
(Did you really press the run button???)
Message 6 of 11
(2,662 Views)
Yes!!
Did you add this VI to a new project? Could it possibly be a project related error?
Message 7 of 11
(2,651 Views)
No.
Message 8 of 11
(2,646 Views)
Oh, what is your OS? From your path formatting, it is not windows.
Did you use the browse button to fill the path control?
Is the file local or on a network location?
Message 9 of 11
(2,641 Views)
Ah! I had the files saved in different folders on my desktop. Pu them in the same folder and it worked. Not sure if that is what was causing the issue but it's working now. Thank you for your help!
Message 10 of 11
(2,638 Views)
