Read CSV file into a 1-D array
Hi
I would like to read a csv file into a cluster of 4 elements
which would then be read into a 1-D array.
My cluster contains a typedef, a double, a boolean, and another typedef.
Basically it could be seen as:
Bob Runs, 4, T, Bob
Mary sits, 5, F, Mary
Bob Sits, 2, F, Bob
Mary Runs, 9, T, Mary
Are there any good
examples for what I am trying to put together that I could leverage, or is it
better to use a different input file than a csv.  I am trying to make my program more flexable
and easier to make adjustments even after the executable is created.
(5,850 Views)
Did you mean to post this in Signal Express or the LabVIEW forum? You don't specifically state in your post which but it sound like you might be asking for help importing text into labview.
You can make a 1D cluster array in LabVIEW that will allow you to index each row and then you can unbundle each entry as you need.
Kyle Hartley
Senior Embedded Software Engineer
(5,830 Views)
Sorry, I must have selected the wrong forum by accident
(5,824 Views)
Accepted by topic author diverdan95
No problem. I went ahead and sent a mod a post to move this to the correct forum.
Anyway, there is a subvi included with labview call "Read from Spreadsheet File.vi". You can find it in the Programming palette in the Fuctions window. You should be able to read your csv file with this and place it in a 2D array of strings. If you want certain types you'll have to do some more conversion. You could use a case statement to check if column 3 is T/F and then output a boolean value to insert into your array of clusters.
This should get you started. If you have any questions please feel free to ask.
Kyle Hartley
(5,812 Views)
(5,798 Views)
