Re: stop "whlie loop" while inside "stacked sequence structure"
Can you give me an example of a state machine like the one you described? thank you🙏
Message 1 of 8
(499 Views)
Hi sinclair,
no need to ask in a ~20 years old thread when you could select the "Create Project…" entry in the File menu and choose the "Simple State Machine" template!
Message 2 of 8
(494 Views)
There is also this: State Machine
Message 3 of 8
(431 Views)
Gerd and crossrulz thank you for your response, previously I will create a program to move 2 motors with very different characteristics as well as the program, here I will create many programs with different motor movements, which will use a lot of case structures that are very stacked. One of the movements that I will make is almost the same as the raw file that I attached.
according to the instructions and examples I avoid stacked whileloops, my problem now is how to find a last value in a new program, without whileloops and without saving it, (the last value must not change before the loop has finished in a structure). how to do it? because it is an important component that must be there to run the program, I hope anyone can help, help me master, thank you very much🙏
Message 4 of 8
(393 Views)
This vi is in LabVIEW 2025. Most people that are going to provide support are not using LabVIEW 2025. You should save for a previous version and save for like LabVIEW 2020. This way you get more help.
Tim
GHSP
Message 5 of 8
(383 Views)
LabView 2008
Message 6 of 8
(367 Views)
Hi sinclair,
thanks for downconverting your code. (Next time please don't rename the CTL file after conversion…)
No, you don't need "a lot of stacked case structures"! Use a better code architecture!
  • Your "old program" is wrong because it uses way too many local variables. Ever heard of shift registers and how/when to use them?
  • Ever heard of "comparing floats for equality" is wrong?
  • Ever heard of "using more than one event structure per VI" is a sign of bad code?
  • What's the point of event structures with a (single!) timeout event when there is no timeout defined???
  • What's the point of an enum typedef when the enum only contains items "0", "1", "2" and "3"? Either use descriptive item labels or simple integer values…
Which "instructions"?
Why do you want to use (or avoid) "stacked while loops"?
@sinclair15 wrote:
my problem now is how to find a last value in a new program, without whileloops and without saving it, (the last value must not change before the loop has finished in a structure). how to do it? 🙏
  • This "last value" should not change inside the loop? Then read it before the loop! (And say loud and clear "THINK DATAFLOW!")
  • Where do you need to "find" that "last value"?
  • Why do you need to "find without using while loops"???
  • Why do you need to handle a "last value … without saving it"???
You really need to learn how to describe/express your requirements much better.
Describing requirements correctly is the first step in creating good programs!
Message 7 of 8
(336 Views)
problem has been solved, just fix the data flow logic, thank you gerd, thank you all🙏
Message 8 of 8
(266 Views)
