Re-create boolean behaviour?
I am doing a check list that is filled out basically with controls (booleans) and calendar controls. The check list must be filled out during different days until completition, and everyday the data is saved on a simple report. I would like to know a simple way to keep the behaviour of the controls once the file is re-opened again, so the check list is re-created automatically every time I would open the file to update (or modify).
Thanks in advance for any advice.
Alejo.
(3,035 Views)
Hi Alejo,
if I get you right, you´re looking for a method to set something default programmatically everytime you end and restart your programm. When I´m right, there are two ways you can use:
1. You could always create your own "default" values by creating an .ini file. You can then save the values to the .ini file to change the default for the next run of the machine. The values are read in the initialization of your program and the values are written to the controls/indicators.
2. If you want to save it programmatically have a look here:
[broken link removed; article no longer available]
Feel free to answer if I was wrong with my understanding to your question.
Alex
NI Switzerland
(3,013 Views)
