Labview 8 exe does not work
I have a Labview 8 application (exe) which works fine on a PC with the Labview 8 development environment  installed on but not on a PC with only the Labview 8 runtime. The error is telling about some missing subvi's. It seems to me that the builder is not including all dependent subvi's automatically.
Does anyone know a (easy) work around for this problem (besides moving back to Labview 7.0 were I never had this kind of problems)?
Thanks!!
See also screenshot with error list.
(3,443 Views)
After a lot of experiments with the application builder, I finally found a solution: installation of the Math Kernel Libraries on the target PC resolved the problem.
(3,439 Views)
Hi Bewin,
I was going to respond earlier, but was drawn away from this answer for different reasons, however as you stated the Math Kernel does not get installed with the LV 8.0 run-time engine, as this is a cut down version.
Hope this explains the error you were seeing.
Regards
JamesC
NIUK and Ireland
(3,430 Views)
Hi JamesC,
Thanks for the link to the full version of the LV8 RTE.
This works also.
Best regards.
BeWin
(3,417 Views)
