Re: Using Simulate Arbitrary Signal
So, I need to use lvm file which has only Y column, not time column, right? Because now, I use lvm file with 2 columns, one is time and the other is Y value. In the Read Measurement Data block I choose the option " First column is time channel" to recognize time, so that I dont have to devide X axis to 1000.
Message 21 of 21
(627 Views)
