Re: Temperature Measurement
Hii i couldn't record the correct mean temperature of a K-type thermocouple, in the LabVIEW, while I placed the thermocouple at room  temperature reading of the thermocouple should be shown a room temperature but it is showing a higher value in thousands,can you please help me how to modify the circuit to obtain a correct temperature reading
(1,594 Views)
Hi Sirishasiri,
Which "circuit" should we modify?
  • A circuit typically refers to some electronics: as we don't have your electronics schematics nor your hardware we cannot help you to modify your "circuit"…
  • LabVIEW is a programming language, storing its code in VIs consisting of frontpanels and blockdiagrams. Should we help you to modify a blockdiagram? How should we modify it when you don't attach the VI?
(1,523 Views)
