Re: Select channels individually to show graph
Hello everyone, I have this problem. I have thirty-two channels. It works in such a way that when the program is run, I click on "start acquisition"
voltage graphs are displayed. If I want just this few channels, I uncheck and show only the one I want.
How do I go about doing it? Is is possible to do so?
I will appreciate your help very much, it will be good if there is a  typical eg I can look into.
(3,824 Views)
This topic comes up all of the time. Most recently is was discussed here. As mentioned, you would use the active plot and visible properties. Do a search for 'plot visible' or something similar.
(3,816 Views)
In fact I want to know how do I go about in grping the channels together. So when I select this channel, it will show this graph only.
I have gone through the egs and there is this "Merge Signals" used to update the graph. I don't really understand how to use it.
I appreciate ur guys assistance.
(3,795 Views)
Hello PSB Singapore
This discussion might be of helpful to you 😉
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,771 Views)
An earlier version of such... here
PS: very much earlier though 😉
Ian F
依恩与LabVIEW
(3,767 Views)
Hi PSB,
  Do you want the output some what like this?
Thanks and regards,
srikrishnaNF
Srikrishna
(3,748 Views)
