Re: File Open Dialog / multiselect / GetOpenFileName API Call
AIR technical Automation
www.air.nl
"AIR Tech. Autom." wrote in message news:...
It can be done, the trick is, indeed, to 'decode' the return message. The
returned message is an 'array' of strings, inLV a string, with elements
seperated with 'NULL', the string ends with 'NULL','NULL', if recall
correcttly.
Another thing is the API you call; GetOpenFileNameW will return names in UNI
code, use GetOPenFileNameA will return names in ASCII, wich is a lot easier
to work with in LV.
Regard,
Wiebe Walstra.
www.air.nl
"Andreas Schmack" wrote in message
news:98ldah$ev6$1@proxy.fe.internet.bosch.com...
Hi!
Is there a po
ssibility to select and open more then one file in some of the
standard file dialogs under LabView at the same time?
A lot of windows programs are supporting multi file selection in their file
open dialog.
I tried to call the GetOpenFileNameW function of the comdlg32.dll but I've
got some problems with the datatype it needs. Non zero-length strings result
to a lot of strange characters in the dialog.
Message 1 of 1
(3,078 Views)
