Random sinwave. Spike removal
I am trying to suppress the first pulse. Is it possible to suppress this pulse? If so what icons would I need to use to supress the pulse. I though of compression?
Message 1 of 9
(4,798 Views)
I want to suppress the signal only.
Message 2 of 9
(4,794 Views)
Your signal looks like a filter artifact, but there could be a lot of other reasons for this spike ( i would call it over shot).
So what are you expecting?
Only a slowly changing DC value?
How are you capturing your data?
What filter do use?
VI?
Simple method: Capture more data and cut 🙂
Greetings from Germany
Henrik
LV since v3.1
Message 3 of 9
(4,755 Views)
Accepted by topic author pnielsen@gplains.com
Second look on the picture:
What is it?
Timescale?
And why do you what to remove it?
There are a lot of vis that could do the job,  you mentioned you want to remove the signal.... so wire a NaN constant to the diagram input 😄
Henrik
LV since v3.1
Message 4 of 9
(4,750 Views)
The signal is a true signal. But "YES" I was asked to suppress the signal. It opposes everthing I believe in but orders are orders.
Message 5 of 9
(4,740 Views)
try a mean filter with the length of the periode.... so about 1 of whatever your timescale is 😉
Henrik
LV since v3.1
Message 6 of 9
(4,730 Views)
Look like some humongous overshoot.  I can't speculate on why the powers that be want to fake this.  Sounds kind of fishy to me.  Wouldn't they rather try to physically filter it out instead?  😞
Just don't sign off on any paperwork.  Make your boss do it.  😉
Bill
CLD
(Mid-Level minion.)
Message 7 of 9
(4,717 Views)
You are 100% correct. If I did not need the job I would tell the ME to fix his valve. This happens allot. I should have stock in Tylenol.
Message 8 of 9
(4,708 Views)
Understood.  Completely.  Good luck.  🙂
Bill
CLD
(Mid-Level minion.)
Message 9 of 9
(4,703 Views)
