Random number generator. Even and odd numbers
Alt is our guiding light.  😉
Bill
CLD
(Mid-Level minion.)
Message 11 of 24
(3,872 Views)
excluding the 'zero'....
Message 12 of 24
(3,861 Views)
@apok wrote:
@RavensFan wrote:
Spoiler
Create the array.  Use quotient remainder to divide by 2.  Now you have an array where all the odd numbers are now 1, and all the even numbers are now 0.  Sum the array and you have the total number of odd numbers.  The number of evens will be the length of the array divided by the # of odds.
"The number of evens will be the length of the array divided by the # of odds."......you mean subtracted not divided?
Yes.  I think I had divided still on my mind from talking about the Q&R function.
Message 13 of 24
(3,854 Views)
Why are you excluding zero?  It is an even number also.
Message 14 of 24
(3,849 Views)
The original problem deals with random number is the range of 0 to 20, thus zero should not be excluded. If zero should not occur, the random generator needs to be changed to generate numbers from 1..20.
Message 15 of 24
(3,840 Views)
i revised my last post to include the # of zero's...
Spoiler
Message 16 of 24
(3,834 Views)
Accepted by Mr_Lordi
As has been said, zero is an even number, so I would suggest not to escalate the issues by adding complications that are not requested.
Here's all that's needed. (I included the random generator, because many users take shortcuts that give lower probabilities for the first and last element.)
Message 17 of 24
(3,824 Views)
sorry for the mis-direction on my part,"excluding zero".....
Spoiler
Message 18 of 24
(3,802 Views)
Thank you very much!
This is exactly what I need, I can´t thank you enough.
Message 19 of 24
(3,751 Views)
Thank you for your help
Message 20 of 24
(3,748 Views)
