Random Aliasing/Data Misread Using NI 5752B
Hello all,
I am using the NI 5752B ADC module along with the PXIe-7972R FlexRIO FPGA. The former just maps out the voltage of an incoming signal across 32 channels, and streams it from the FPGA to the Host PC through a DMA FIFO (First In First Out) memory buffer. I have noticed that at times, when I am reading in the the signal with LabVIEW, I get some sort of aliasing which seems to be in a somewhat regular sample range (for example, 1171).
I've attached a photo of how it looks. It seems to always be around 1171, or 2200-something. The code I am using is built upon LabVIEW Examples, also attached.
I have a feeling that it could be due to the FIFO not fully flushing, and having remnant samples. Am I missing something here? Could I be missing a "Reset DMA FIFO" function somewhere?
Any advice is duly appreciated.
(858 Views)
Can you attached the LabVIEW project?
The examples are written to get bursts of data.  How are you ensuring that things remain continuous?
ALE Consultants
(833 Views)
