RUN TIME
Hi everyone,
I need help with Run-Time Labview. I build an application (exe) with Labview 8.5 Professional and I'm trying to run this executable with Labview Run-Time 8.6 but I got an error.
Are the two version compatible. I can run an application build with an older version with a newer one?
Pierpaolo
(2,977 Views)
NO,
Build in 8.5 run with 8.5 RTE the
"Should be" isn't "Is" -Jay
(2,975 Views)
Is this true for all labview version?So the RTE can run only applications build with the corresponding LABVIEW verison?
Pierpaolo
(2,967 Views)
Pierpaolo
YES, its true. Take a note - RTE is free, so you can download and install LabVIEW Run-Time 8.6 for running application developed with LabVIEW 8.6.
(2,959 Views)
Thanks guys for your help
(2,952 Views)
