RTD Configuration
I am designing a system that reads and logs measurements from 3 RTDs. I am using the NI 9217 RTD to acquire the temperature readings and have been able to display the temperature readings in LabVIEW.  However, the temperature readings are not correct.  I know this has to do with the setup of the RTDs.  However, I am not sure if I need to select  PT3750 or the other preset types or use the custom.  The RTD model we are using is from Omega.com and is part # PR-10-2-100-1/4-12-E.  I have tried to find the A,B, and C coefficients from Omega.com, but all I can find is an alpha value of .00385.  How should I set up the RTD input for this model number?
(18,272 Views)
Hi NT
You would use the Pt 3851 and a Ro of 100.  I could not find a Iex Value A (execution current) from the omega website, so you may need to try different values or contact omega for this information.
The alpha value represents the ohm/ohm/'C, and the IEC 751 standard RTD, which is the type that you are using,  uses alpha=0.00385 (actually it is alpha=0.00385055 and in RTD task setup it is Pt 3851).
Chris
Message Edited by Chris_K_ on 09-02-2008 12:00 PM
(18,237 Views)
Maybe too late already,
But just for the record:
Create your TASK
Place a DAQ Channel Properties node, and wire the task into it
In the DAQ channel properties node, select:
    analog input-temperature-rtd-custom-A and then B and C
This way you can set the ABC parameters in your temperature TASK !
(17,827 Views)
Hi Chris,
The link doesn't work anymore (I know, it's been years) - but would the information from the link be located somewhere else?
Andrea
(16,991 Views)
I am unsure of the information you were seeking from the link in the earlier post, but here is what I found based upon the original question posed.
Creating Virtual Channels for RTDs in NI-DAQmx and Traditional NI-DAQ
Temperature Measurement with a Thermocouple or RTD
Taking Temperature Measurements with RTDs: How-To Guide
Hope this helps,
Patricia B.
(16,885 Views)
Thx! More than 7 years after you posted it but it helped me!Smiley Happy
(11,288 Views)
