How to display waveform graph data from dataset with .DAT file extension
i just installed the labview tool kit, and in example folder i found example data of good bearing and defected bearing, but i dont know how to display the waveform of the example data because it has .dat file extension. is anyone have the example program to use these example data?
(3,611 Views)
i got the data from here
(3,610 Views)
Hi suda,
So you installed that toolkit and found the example data.
What about all the VIs (and other stuff) of that toolkit? Why not use them to load those dat files?
(3,584 Views)
