RT to FPGA transfer via DMA FIFO data access
I am trying to send data via DMA FIFO to the FPGA from an RT. The program is running and behaving the way it has to. After finishing, the data has to be saved in a file so i can use it to work on it.The issue is that it seems like there is no file created. If i am searching for ftp://<ip address> where <ip address> is the IP address of my CompactRIO System i´m not able to find anything.
I am working with Labview 2018 and cRIO-9035
Any help would be greatly appreciated.
(2,274 Views)
Accepted by Alpview
Hi Alper,
as has been told to you in the German LabVIEW forum: use WebDAV instead of FTP…
(2,266 Views)
