RT engine restart
hello,
Can anybody open the examples given here:
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3ECF756A4E034080020E74861&p_node=174824&p_submitted=N&p_rank=&p_answer=&p_source=External
I would love to know how I can programmatically restart
my RT engine but cannot open those VI, error window says it is brocken and has no diagram.
thanks for help.
(3,942 Views)
Hi, Alle,
Do you have LabVIEW 7.0 or 7.1? Probably that is the case, and that is why you are not able to open this VI. New with LabVIEW 7.x, there is a VI that programatically allows you to reboot the controller. Just go to you Block Diagram and in the Functions Palette, go to the LabVIEW Real-Time palette. Find the Real-Time Utilities subpalette and in there you will find the "RT Reboot Controller.vi". That should do the trick for you.
GValdes
(3,942 Views)
Actually, the link provided was a VI saved in LV 6.1 with no diagrams!
Ben
(3,942 Views)
