‎06-28-2016 11:40 AM
‎06-29-2016
07:41 AM
- last edited on
‎06-02-2025
06:01 PM
by
Content Cleaner
What kind of camera are you using? Does it have hardware trigger functionality? Does your flash have hardware triggering too? What kind of I/O modules do you have in your compactRIO? The best option here will be to use a digital output signal as a hardware trigger to acquire an image and strobe the flash on the same rising/falling edge. Many camera will also allow you to set a trigger delay in case you want to start acquisition (exposure) a short time after the trigger is actually received.
A timed loop or sequence might be able to synchronize things enough if hardware triggering is not an option. You can learn more those structures here: https://www.ni.com/docs/en-US/bundle/labview/page/controlling-timing-in-labview-applications-real-ti...
‎06-29-2016 09:47 AM
Thanks for the answer. The camera is just an analog camera connected through the Movimed AF1501. It does. My "flash" is not really a flash but a custom made LED lamp, controlled with the ni 9474. Those two are the only modules I have in the cRIO.
So you think the best option is using hardware triggers and not through programming?
‎06-30-2016 11:22 AM
In almost all applications, hardware triggers are going to be better synchronized than any software trigger you could develop. Not knowing anything specific about your camera, I would agree that synchronization should be done through hardware triggering.
