RT Reboot Controller and MacID
I've a little problem using RT reboot controller.vi.
I Obtain programmatically the MacID of my PXI 8196 but I cannot use it with RT reboot Controller.
I've got the MacID in a string for ex: 00-80-10-21-30-12. But this MacID must be entered in this vi in hexadecimal format. SO I have to pass this string in hex format and enter 008010213012.
How can I do this?
Julesjay
Message 1 of 9
(8,625 Views)
Try converting each octet into hex. For example, 00-80-10-21-30-12 would become 00-50-0A-15-1E-0C.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 9
(8,616 Views)
Hi Mikeporter,
Thanks for your answer.
I've found a solution at my problem. But i'll try your suggest to see which solution is the most efficient.
Thanks.
julesjay
Message 3 of 9
(8,585 Views)
HI Mikeporter,
I've tried your solution but it doesn't work? I don't know if I've understand your suggest!
Have you tested it?
Message 4 of 9
(8,441 Views)
No, I did not test it because I have never had the problem that you are experencing. It is just that I have never seen a MAC address that contained no hex digits (A..E) - though it is certainly possible to have one. My suggestion was simply offered as one more thing to try.
How exactly are you getting the computer's MAC address?
Mike...
LabVIEW Champion
Message 5 of 9
(8,431 Views)
I used the ARP dos command. It takes only fews millisecond while Pingcontroller.vi takes 20 secondes to get MacID and IP.  Have you any idea why this vi is soo long?
julesjay
Message 6 of 9
(8,028 Views)
Here is the way I use to convert the macID string.
1. First with exec.vi, I type the command DOS  arp -a which returns a string like 00-00-0c-7a-7f-de for macID. It's easy then to obtain the string 00000c7a7fde.
2. Then I use a vi from FPGA library named nirviHexStringToByteArray.vi which is located in C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\rvi. The result ByteArray       is transformed into string by ByteArraytoString.vi and it's done.
3. Now when I swicth my string in hexadecimal it displays 0000 0c7a 7fde.
I don't know which operation is done in this vi but if you know it I'm interessed!!!
Julesjay
Message 7 of 9
(8,020 Views)
Well, I'm not sure what is in that particular subVI, but the conversion isn't hard to do. See example...
Mike...
LabVIEW Champion
Message 8 of 9
(7,866 Views)
I've tried this and it works very well.  thanks  Smiley Happy
I've tried many possibility very similar but never with the vi you used.
Thanks a lot
Message 9 of 9
(7,694 Views)
