RT - Configure time of real time target in MAX
Hi
I want to manually change the time on my real time target (cRIO 9022) using MAX
I follow the steps described here;
http://digital.ni.com/public.nsf/allkb/FAB0EC4D6E5EE0F386257738005733A3?OpenDocument&metc=max_MAXDat...
On step 2, when installing the NI System Configuration Remote Support 14.5.0
I get the following error message when trying to install:
"Labview Real-Time 12.0.1 requires service locator 1.0"
On the host computer I had Labview 2013 SP1 with Real Time module 13.0.1
On the cRIO I'm running Labview RealTime 12.0.1
I installed Labview 2012 SP1 with real Time Module 12.0.0 on the host computer and tried again.
Then I got this message:
"Remote panel Server for Labview RT 13.5.0 requires Appweb 13.5.0
Run-Time Engine for Web Services 13.5.0 requires NI System Web Server 13.5.0
I have searched the forum with no luck
Any help i appriciated.
BR
Arne M
(3,142 Views)
Accepted by topic author arnemad
Hi
I solved the issue.
Just had to select the correct releases of all the needed additional software
NI System Configuration Remote Support 5.6.0 etc.
(3,115 Views)
