RT Build and Deploy cRIO - Why Extra VI Compile
Hi all,
We are developing a somewhat extensive embedded application that runs on a cRIO-9049
The project is constructed with
- multiple libraries (not packed )
- no shared variables
- no load from references
- many vis are inlined for performance
- VI have 'separate compile code' option
- the project as about 2000 VI
When I build the application with many of the compiler options but not
- remove type_def
- not remove inline VI diagram
 At the end of the compiler process it saves all the VI... I guess with the optimized compile code.
The big mystery is when I come to ' Set as startup', there is an additional compilation of up to 100 VIs ad then the deployment loads in another large handful of VIs.
My questions are:
1. if I have just build an exe why is there more compilation at deployment
2. Why is there extra deployment of VI.  I would have thought that there ALL contained in the startuprt.exe
3. If we have an extensive library structure in the BUILD config do I need to link the libraries in using the 'Always Include' options
thanks in advance
Message 1 of 1
(2,333 Views)
