RS232 data communication
Hi All,
I am trying to read the data from a hardware, which transmits 5 data packets/sec and 1 packet=4 bytes, through RS232 to PC. RS232 baud rate=2400 bps. 1st byte is a 'START OF DATA' marker (set as =65). Next 3 bytes are then processed and calculated 'TOF' is being saved in a file. Every 30 min  file name is being changed.
Now problem is as this :- I should receive 5x60x30 number of data points (TOF) in each 30 min , But in real I am receiving variable number of data points for each 30 min data file.
Please go through enclosed VI and suggest.
Pl note: I am using workstation with dual core processor and 4GB memory.
jayant
(2,669 Views)
I don't typically use occurrences but I think you may have a bit of a timing issue with your parallel loops and your stop button.
I think I'd ditch the stacked sequence in your consumer loop and pull your file write into your consumer.
Your end logic for writing the Stop local doesn't make a lot of sense.  If you make it to those comparison functions, then all of your loops have been stopped and there should be no need to set the local.
(2,649 Views)
