RS232 comunication
Hello everybody!
Here is my problem: I have a frame of data from ADC (atmega 32) in 16 - bit array: 165|90|2|counter|byteADC 1| byteADC 2| byteADC 3| byteADC 4. How can I extract data (byteADC 1 etc.) from this frame? 'I' is a separator. I tried to save this frame to array of strings but with no further result. Have you any idea how to do this? On the end I want to present data in real time on chart.
Message 1 of 9
(2,948 Views)
I would use the Spreadsheet String to Array function with "|" as the delimiter.  Then it is a simple matter of just indexing out the data you want.
GCentral
Message 2 of 9
(2,940 Views)
The Spreadsheet String to Array works and all you have to do is index the array. Post an image of your block diagram if you still have problems after doing this.
Message 3 of 9
(2,937 Views)
Okay, I'd like to extract a counter from my data frame and view number of count in each iteration. But it doesn't work.
Message 4 of 9
(2,926 Views)
Wire in a 1D array to the type input of the Spreadsheet String to Array function.  Then you will just have a scaler coming out after you index the element you need.
GCentral
Message 5 of 9
(2,909 Views)
You're going to have to be a bit more precise. A simple statement of 'it doesn't work' is pretty meaningless.
Message 6 of 9
(2,908 Views)
Yeah, sorry for that. Ok, I'm going to improve my program, but how can i limit incoming data to array? 165|90|2 it's a starting index, and in that way i recognise where frame starts. Should I try something like cyclic buffer or prepare 'for' statement? Which solution is better? Thanks for your past answers.
Message 7 of 9
(2,900 Views)
You are already limiting the data. The read is set to automatically terminate with s termination character so the byte count just had to be set for some arbitrarily high number.
Message 8 of 9
(2,891 Views)
It's AMAZING how simply it is! 🙂 It really works, thank you a lot!
Message 9 of 9
(2,875 Views)
