RS232 Connections with LabVIEW
For a research project, we need to use RS232 connections to communicate with a device (Control and Data Log) that we are planning to use. Therefore, kindly request your suggestions on how we can use RS232 connections along with LabVIEW.
Message 1 of 9
(2,698 Views)
VIWeek 2020/Proper way to communicate over serial
Message 2 of 9
(2,686 Views)
That link actually gave me some great ideas on how to refactor my existing serial port routines.  (I looked it up a while ago when you first posted it.)  I suck at setting up serial port comms, but I suck less at it now.
Bill
CLD
(Mid-Level minion.)
Message 3 of 9
(2,655 Views)
The bad part is that some engineers think "ah, here's some code from the 1950s!  That should work!"
The worst part.... It still works.
"Should be" isn't "Is" -Jay
Message 4 of 9
(2,648 Views)
Just because code is old does not mean it is bad and/or there is a better way to do it.  Granted, my old code was horrible because I learned better over the years.  But if you can take the code somebody did 10 years ago and use it, it is probably at least decent code.
Message 5 of 9
(2,639 Views)
Well I learned better when I first watched your presentation.  😉
Bill
CLD
(Mid-Level minion.)
Message 6 of 9
(2,610 Views)
OK we've gone off topic!  Somehow that doesn't disappoint me.
RS-232,   you should know that the RS is short hand for Recommended Standard.  Isn't that a wonderful oxymoron?  So, you need to Read The Friendly Manual, RTFM, for the device to learn how that engineer implemented RS-232 on that day.  There are several different ways it can be done.   Some ways should be drawing a pention.
Message 7 of 9
(2,580 Views)
Continuing with the off topicness...
RS-232 only defines the hardware level.  The voltage shall be -12V for a 1 and +12V for a 0 (or something like that, it has been a long time since I read it).  What we normally think of RS-232 uses a byte protocol called UART, which defines how to read the 0s and 1s into a byte.  There are then a gazillion (estimated) message protocols on top of that UART protocol which is on top of RS-232.  RS-422 is the same way (only defines a differential pair to define a 0 and 1).
Message 8 of 9
(2,562 Views)
Tim, you are mixing layers!  The 232 phy layer may be 3, or 5 single ended wires or up to 9 wires .  3v3 single ended is common these days since it doesn't really take a huge current to charge a mosfet gate at high speeds.
Drop down to 77-300 baud over 56k copper phone line and ..... well, do the math.  Two twisted pair, 24 differential volts, a few 12v lead acid batteries and some relays makes sense. <that level of technology still drives most RR crossings>
The driving code should post date the machine at Union Station in Chicago.   But, thanks T.A.E! that computer still works today.
History lesson off
Message 9 of 9
(2,499 Views)
