ROI
Goodmorning, I am new to labview and I have to take four ROI on a single image before the image is acquired and in the all  example I have found they are taken after. Has someone some example that an be useful?
thanks.
(3,324 Views)
Please explain in more details what you mean by "take four ROI on a single image before the image is acquired".
An ROI is a Region Of Interest in an image.
It can be a hardware ROI, so the camera directly gives a sub-image.
It can be a software ROI, so that filters and other processing can be applied on specific parts of the full image.
Raphaël.
(3,316 Views)
I have a basler camera that can "focus" on four region of interest before I acquire the image and as a result it gives me a single one image with all the four ROI. In the basler software I can decide the coordinates of the four ROI and it gives me a single image. How can I do that on labview? How can I choose before acquiring the image the coordinates?
(3,309 Views)
Accepted by fra24
If you want to manually select 4 ROIs you will need an indicator and an image with the same resolution, a previous capture would do nicely.
Use the ROI tools to select your ROIs, use the CTRL + click and drag to add a new ROI. The ROIs are stored as a property of the indicator. Use IMAQ Ungroup ROIs to separate them.
(3,285 Views)
