RLS encoder slow down while loop execution
Hi Ryan,
@Ryan777 wrote:
I was wondering how do I connect it up to LabView to read the data that is produced?
Use the USB cable coming with your sensor and plug it into a free USB port of your computer…
(A virtual COM port (VCP) should appear.)
@Ryan777 wrote:
As for sending the commands to the encoder, how do I go about doing it?
Use VISA functions to send commands (VISAWrite) and read responses (VISARead) with that VCP…
What have you tried and where are you stuck?
Message 11 of 33
(2,948 Views)
Hi GerdW,
I am relatively new to Labview but this was what I came up with but there is no output data from my end. Am I missing something? Your help would be greatly appreciated!
Thanks!
Ryan
Message 12 of 33
(2,941 Views)
Hi Ryan,
why do you wire "i" to the "number of bytes" input of VISARead? Use a numeric constant set to the expected number of bytes in the response of your device!
Where do you send the command (as described in your PDF) to your device?
Do you get any error message when stopping the VI?
Do you get any received string (before you convert the string to number)?
Did you take the Training resources as offered in the header of the LabVIEW board?
Message 13 of 33
(2,932 Views)
Hi GerdW,
I have made adjustments based on your advice and these are the following results. I changed the block diagram and added in a VISAWrite.
I finally got some output data but the data looks like its the data for version request as shown below. (Data shown below is string data)
When I keyed in commands to view the data, nothing changes. Is my VISAWrite placed incorrectly?  Thanks in advance!
Ryan
Message 14 of 33
(2,887 Views)
Hi Ryan,
@Ryan777 wrote:
I finally got some output data but the data looks like its the data for version request as shown below. (Data shown below is string data) … Is my VISAWrite placed incorrectly?
The VISAWrite seems to be placed correctly.
The data shown in the image indeed looks like the respoonse to an identification command. Did you read the manual to learn how to parse that answer?
Did you type the commands exactly as is described in the manual?
Did you type the correct TermChars? Most devices don't answer until they receive the needed TermChar…
Message 15 of 33
(2,868 Views)
Hi GerdW,
I managed to get data readings by sending commands to the encoder. However, the data I am getting is in Hexadecimal as shown below. For the string conversion, I can't seem to find one that can output can data in decimal format. The following FAFB C000 corresponds to the the angle 352 and yes when I rotate the encoder, different Hexadecimals will be shown. Do you know how I can get my data in degree based on my given output?
Thank you.
Ryan
I used a Hexadecimal string to Number function but no data is shown on the indicator.
Message 16 of 33
(2,881 Views)
Hi Ryan,
did you read the manual?
Command "3" gives you the "absolute encoder position", described as
3 bytes binary absolute position, big-endian, left aligned
1 byte detailed encoder status
So you need to read 4 bytes and convert the first 3 bytes into an integer number:
"FAFBC0" results in a position of 16448448…
Message 17 of 33
(2,869 Views)
Hi wiebe,
why do you use "AND 8" to get the status? I would use "AND 255" instead…
Message 19 of 33
(2,851 Views)
Hi GerdW,
Thanks for the help so far! Lets say if my Hexadecimal is "FAFBC000", how do I edit your block diagram so that the conversion involves the first 5 characters "FAFBC" instead of "FAFBC0"
So the final decimal output will be "1028028" instead of "16448448".
Thank you.
Ryan
Message 20 of 33
(2,822 Views)
