RE: Graph Problems when running same LV-application on different Win-OS
I have seen a similar problem.
Sometimes the second axis is right ontop of the first making it hard to
read.
Not sure why yet....
(I am also using a Win 98 exe on a Win NT box)
PS I have installed the correct version of LabVIEW runtime...
> -----Original Message-----
> From: comp.lang.labview@omigatech.co.uk
> [mailto:comp.lang.labview@omigatech.co.uk]On Behalf Of ttLied
> Sent: 31 October 2001 14:48
> To: comp.lang.labview@omigatech.co.uk
> Subject: Graph Problems when running same LV-application on different
> Win-OS
> I have built an application in LabVIEW on a Win2000 computer. Running
> the application on this computer is OK. Problems starts when
> installing on a NT4-computer. So far, I
have noted that it is not
> possible to change autoscale settings for graphs, and the plot colors
> are not as specified by my code. I use the latest avaliable version of
> LV and builder. Any ideas on how to solve this are apreciated.
(2,793 Views)
I've had the same problem before. Greg McKaskle once made a comment, that
he's seen strange things when the font doesn't exist on both machines.
That seems to be the case. I've found that if I choose a real True Type
font (like Arial), that's on both machines, rather than using the
"Application Font" or the "System Font", then I don't have the problem.
It's kind of awkward, since, I'm always having to change fonts whenever I
put together a front panel, but it seems to work.
Bill
Duncan Rutherford wrote in message
news:NEBBJMJAALFIBHILKDJNMEIECJAA.duncanr@omigatech.co.uk...
> read.
> > Win-OS
> > installing on a NT4-computer. So far, I have noted that it is not
(2,793 Views)
NI were able to reproduce this problem in the UK.
The resolution to the problem was to use the 6.02 runtime engine.
(2,793 Views)
