RAW DATA TO VOLTAGE
Anybody that uses Advantech library for Labview?
I have an Advantech PCI-1711 Data Acquisition Device and I receive an unconverted raw data using a block from Advantech, then I would convert this binary raw data to the correct voltage, so I use the AiScale.vi block from Advantech but this block has some inputs that I don't know what are the meaning of them, for example, Maximal voltage of current gain., offset (Binary offset for zero voltage (0V)) and Maximal count (2N) of N bit D/A conversion. The problem is that I don't know what values are the correct for these inputs.
Thanks in advance,
ToNi.
(2,590 Views)
Hello ToNi,
Is there any help for the Advantech function? If not, I think they could give you a better explanation of their funtions.
Have you tried in their Forums or have you tried to call them?
I hope this helps
crisR
(2,567 Views)
