R&S Spectrumanalyzer FSEM, How to make a Hardcopy via GPIB with Labview 14 ?
I have here an very old FSEM Spektrumanalyzer from Rhode & Schwarz and we want eleminate the floppy disk in our lab.
I can control the Basic functions from the  FSEM via GPIB with Labview 14 so far with the Labview Driver from R&S.
We try to use the "HCopy" function from the handbook but without success so far.
Have anybody an Idea of the right command an "VI" that I can use in my applicaton to get the screen shot from the FSEM transfered via GPIB to my Windows PC ?
Thank you for you feedback
Message 1 of 14
(5,922 Views)
Hi rf_antenna_guy,
what drivers version do you use?
BR
Milo
Message 2 of 14
(5,912 Views)
for the R&S FSEM (without NT Operation System)  I use the Driver from the NI download page, the Version is 1.0.
Labview Version 14.for Windows 7
And NI USB to GPIB Adapter is a 187965H
Thx
Message 3 of 14
(5,905 Views)
can you write here a link to the driver? I cannot find it.
Thx
Message 4 of 14
(5,886 Views)
I changed the driver to version 3.8.0 (original version was 3.7.2):added a possibility to transfer files and added one example for Hardcopy. Only tested it with R&S FSW, since it is not possible to get my hands on a FSEM.
Let me know how it went.
BR
Milo
Message 6 of 14
(5,855 Views)
Hi Milo,
thank you very much  for your quick response.
I install your new lib inside the Labview, Libary Folder and I want to test it.
But...I couldn't manage to run it so for far 😞
Under which VI Palette you add the Hardcopy and Transfer Palette ?
I could't find it the example   in the zip file ?
Sorry for the  additional confusion from my side
Please can you give me a hint... I am more an expert for RF Stuff instead of Labview so far but I want to improve it.
Regards
M.
Message 7 of 14
(5,852 Views)
Hi RF_Antenna_Guy,
sorry, forgot to add that into the palette... replace the attached palette files
And also in the main palette file, I added VI_Tree.vi there. If you open it, you see all the driver's VIs.
BR
Milo
Message 8 of 14
(5,848 Views)
Hi Milo,
I tested your VI example and it safe the hardcopy as a WMF file to the internal Memory of the FSEM.
But at the end of the Programm it  stopped with an error and the file is not copied to the Windows PC.
See attached Picture of the failure message.
Please could you give me again a hint to solve this ?
Thx
M.
Message 9 of 14
(5,833 Views)
Accepted by topic author rf_antenna_guy
Hi M,
write me on miloslav.macko (ad) rohde-schwarz.com
Milo
Message 10 of 14
(5,824 Views)
