R/W cluster element through property node
I have retrieved an array through property nodes using the value property, but haven't found a way to do the same with a cluster. Am I missing something?
Glauber
(3,188 Views)
You can create a value property node for a cluster. But what you are probably seeing is that the value is returning a variant. If that is the case you have to convert the variant to a cluster using the Variant To Data prim. Define the data type with a constant created from your cluster.
Edit: The cluster should be a typedef before you create a constant from it. Otherwise you will have a mess when you modify the cluster.
LabVIEW 2012
(3,178 Views)
Look at the following:
https://decibel.ni.com/content/docs/DOC-3446
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,174 Views)
Accepted by Glauber
Ah yes. If you want to get an individual element then read the document Adnan Z linked. From the title this seems like what you want to do but from the body it looked like you wanted the whole cluster.
LabVIEW 2012
(3,172 Views)
Thanks!
(3,160 Views)
